Old 05-23-2011, 04:12 PM   #18 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
You can't spray enough water on a radiator to cool it w/o a continuous flow of water.
You are beating a dead horse.
Install an electric fan in front and set on a push instead of a pull function. install a manual switch or a temp comtrolled switch.
put a shroud around the fan to keep the airmoving thru.
You can dance all around this water issue but it is impractical.
someone mentioned the sprayer on the a/c. remeber this system is runnung off a water hose that is 'on' providing a constsance source of water
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
