Old 05-25-2011, 11:23 AM   #47 (permalink)
curv872
Originally Posted by johnf36 View Post
Cool so you already did a body pan?
Yup, that's the "underpanel", single 4x8 sheet of coroplast ripped into 2 2x8 panels cut to fit, the sides, as you can see, tuck under the exhaust heat shield (edges were also tapped with aluminum tape for further heat resistance) and the outer sides tuck under side sills. The front end is folded up behind the wheels wells so it doesn't scoop any air above it.
