Old 05-23-2011, 04:21 PM   #41 (permalink)
Thanks, they have be on for 2 years
Old 05-23-2011, 05:18 PM   #42 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Looks good & stealthy.
Old 05-24-2011, 08:35 PM   #43 (permalink)
Originally Posted by johnf36 View Post
Looks great thanks for sharing, how did you anchor the front? Have you seen the retro fit GP body pan??
Back on topic
Here is how the diffuser and underpanel attach to each other.
The aluminum bracket it attached to the subframe with a toggle bolt.
Old 05-24-2011, 10:33 PM   #44 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Originally Posted by curv872 View Post
Back on topic
For your toggle bolt, are you using existing holes? or did you drill into the subframe?
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 05-24-2011, 11:41 PM   #45 (permalink)
Existing holes FTW!
Old 05-25-2011, 04:56 AM   #46 (permalink)
Cool so you already did a body pan?
Old 05-25-2011, 10:23 AM   #47 (permalink)
Yup, that's the "underpanel", single 4x8 sheet of coroplast ripped into 2 2x8 panels cut to fit, the sides, as you can see, tuck under the exhaust heat shield (edges were also tapped with aluminum tape for further heat resistance) and the outer sides tuck under side sills. The front end is folded up behind the wheels wells so it doesn't scoop any air above it.
Old 05-25-2011, 11:19 AM   #48 (permalink)
rolling around under the cr-v last night, i saw not only holes, but THREADED holes. woot! too sweet.
Old 06-01-2011, 04:48 PM   #49 (permalink)
Food for thought:
" "Aero is more about the rear of the car than the front," said Freeman Thomas, director of strategic design at Ford, as he walked through displays at the recent Los Angeles Auto Show. Problem-causing drag behind the car stems not so much from frontal resistance as from swirling eddies of turbulent air at the rear"
Old 06-01-2011, 09:34 PM   #50 (permalink)
Dr. Jekyl - '09 Mini John Cooper Works
90 day: 47.07 mpg (US)
Added Airtabs
Food for thought:
I took that sentiment quoted above to heart and applied a set of vortex generator tabs to the roof and rear seat side windows of my Mini. I applied a total of 14. Eight on the trailing edge of the roof and three on each of the two rear seat side windows.
I'll post results when I accumulate a few tanks of driving with them. So far, I've noticed the rear glass and hatchback appear to be staying cleaner than before. That's a welcome result.
2004 MINI Cooper S - Improving Aerodynamics iplaysdrums Aerodynamics 90 08-08-2012 02:13 AM
Drag Racing Aero Help Bennett_Racing Aerodynamics 33 06-28-2010 06:02 AM
rear diffuser fabrio. Aerodynamics 30 05-17-2010 12:36 AM
rear diffuser build thread LeanBurninating Aerodynamics 24 06-06-2009 08:32 PM
