Thread: WAI commentary
Old 05-25-2011, 05:23 PM   #8 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Nope, it keeps the ratio at stoichiometric. The result is lower power output for a given throttle opening. To maintain speed, you must therefore open the throttle further. This decreases pumping losses which increases efficiency. Also the warmer air promotes a faster burn I believe, which leads to higher peak cylinder pressure and additional torque.
If it does produce higher peak cylinder pressure, wouldn't that also accomplish one of the goals of advancing the timing a couple degrees?
