More pics on the front:
I only used 2 pieces of aluminuum angle. the center piece is there to anchor the one piece choroplast sheet from flapping
I cut the choroplast to fit all the way under the front lip.
I then used a flat piece of aluminuum and 4 sheet metal screws to anchor the center line to the aluminuum angle bar that runs down the middle
you can see the factory shields that sit in front of the tire. I made a set uot of choroplast and put them at the exact same angle.
