Old 06-23-2011, 02:50 PM   #3 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Frank makes a good point. Flow Illustrator is only in 2-D cross-section. A vehicle moves through the air in 3-D. Do we assume that the sides of this cap are solid like Bondo's hinged aerocap, with flat plates instead of a hatch? I sure would like to see someone build and test a version of this idea.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
