Old 06-24-2011, 03:02 PM   #1 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Hot-wire cutting foam for aero-mods
Does anyone have experience with hot-wire cutting in terms of using it to cut foam for aerodynamic modifications to cars?
I have this idea about making a pickup truck cap out of a bunch of of sheets of 4" thick white styrofoam that I rescued from a dumpster.
I would stack them up, and then "sculpt" them into shape with a hot-wire cutter.
I had a dead toaster, so I took it aparts, ran a section of the heater wire between two screws on a non-conductive wood frame (sort of like a bow-saw), and put power to it through a lighting dimmer.
At about 250 watts, the wire glows a nice warm orange and slices fantastic through the foam.
The big drawback I have noticed, it that even though the wire is taut when cold, it droops and goes slack when warm. This makes it hard to cut a straight line! Perhaps I can add a small spring to keep the wire tight whether it's hot or cold?
Anyone have experience with a hotwire cutter and can give any advice?
(I am running this through a proper fuse-box, a GFI outlet, a dimmer switch to control current, and know better than to touch it!)
Ok, so, any advice other than "Please don't electricute yerself!"?
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
