Nice drawing, cfg83!
What are those black plastic lug nut things? A Saturn brand item, or GM, or ?? I likely will stay with my (already) drilled out HX lug nuts but I think the plastic ones might be useful for some EcoModders.
Originally Posted by cfg83
brucepick -
I think it depends on the back side of the lug nut cap. If the nut can lie flat and flush on the back side of the lug nut cap, then I think you are ok.
I used a no-epoxy design in mine where the T-Nut spikes just "grab" the inside of the plastic lug nut :
However, this requires that I screw the bolt onto the plastic lug nut *before* I take the lug nut off. Otherwise the T-Nut will fall out when I take off the plastic lug nut.
CarloSW2
