FWIW, Toyota put out a TSB when it went to 5W-20W oil in its 2007 engines and certain 2006 engines. The TSB did NOT recommend the lower viscosity oils in older Toyota engines. I think newer Toyota engines are built with tighter main bearing tolerances.
For that reason alone, I believe the OP should stick with the oil viscosity recommended by Honda when his car was built.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
