Old 09-13-2011, 09:02 AM   #9 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I don't believe there are any DX trim Civics with lean burn, but I guess I can't claim to know for certain. I think only the HX will offer that in the sixth generation. What trim was this 2-door silver coupe?
Something to think about with the Civics is the gearing, which varies significantly with the trim level. The sixth gen HX and DX have the same transmission gearing, but the HX has a taller (read "better" FE) final reduction gear. Changing the final reduction gear would merely be a bolt-on affair. The EX has less desirable gearing from an FE standpoint.
james
Originally Posted by creosote7 View Post
I've driven a stick since high school so no problem there..Just having a very hard time finding a good civic w/ manual tranny that's not ragged out. Found a nice 98 silver 2dr coupe with manual tran. the other day and turns out it had a new engine put in it at 170k..now it has 179k miles. So that makes me nervous.
I'm a little confused on the "Lean Burn" ability of the civics..At first I thought that only applied to the HX, but it seems that others with LX, DX, talk about lean burn. Could someone explain what civic have that option and is it a good thing? I've read here about Scangauge having problems reading accurate MPG with lean burn mode.
thanks again for help...
