Old 09-17-2011, 07:07 PM   #2 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I don't do this. But I do sometimes continue coasting toward a closer spot or a higher spot when I have too much momentum left over. At that point I'm looking for a better way to start out when I return to the car. Coasting down a hill in the lot and bump starting saves starter motor usage, and therefore fuel. But I think you have it correct otherwise... mostly... there is a value I guess to practicing that sort of planning, because you need it in all sorts of hypermiling techniques and it is not part of normies' driving styles.
Originally Posted by MPGranger View Post
I fail to see how coasting around your parking spot actually teaches you to raise your FE. It seems to be more about increasing your status as a hypermiler by getting a higher MPG figure, than actually getting practical FE. I understand it might be part of getting competitive about the FE game, but it seems to be a vestigial parlor trick.
Could somebody explain this better, so I might understand the function better?
