Originally Posted by brucepick
I can also reduce and then eliminate the fins. That would make it pretty much as if it were made with a taller trunk, with the trunk trailing edge at the template point.
That would make your design a vague reference to the Civic Del Sol's window/trunk transition:
I wonder if you could pick any design features from the compasrison that would help you shaping the final version.
