Originally Posted by Vekke
If you want legal HID lamps go to Hella | Homepage.
Your lights should have D marking in them to be able to use these aftermarket kits, legally
Anyway it was a good video on the topic ![Wink](/forum/images/smilies/wink.gif) .
I am disturbed maybe once a month about someones drive lights. Some of those are also regular lights which has just been adjusted wrong. You are not supposed to try to read the other cars licence plate number when you face it on the road...
Vekke,
So I understand the op's post and your reply.
HE wants to STOP using his factory halogen bulb and intall and HID bulb / ballast.
You want him to buy an aftermarket "ADD-On" hid from Hella.
1. if he follows your recommendation, then he has the factory setup AND the add-on. Since HELLA doesnot make factory replacement headlamps for direct consumer purchases.
2. the op wants to REDUCE his electrical consumption, not increase it.
3. And why Hella??????? Any sealed aftermarket hid system will do the same thing....PIAA for example.
