Old 10-05-2011, 11:24 AM   #3 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Do you have a kill switch, or are you using the key?
I installed an injector kill switch with a friend. It cuts-off the ground. When I time it right, the UG does not even go black temporarily. But it has always been the case that in the "run" position, with the injectors off, the speed average starts climbing steadily, almost as if it is calculating distance traveled in some unknown metric.
MetroMPG (10-05-2011)
