Old 10-11-2011, 10:23 PM   #346 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by PaleMelanesian View Post
Try using a 1-2" opening on both the driver's window and the right rear. Minimal aero drag, but lots of airflow through the car. If you need more, go to 4" driver and 2" on each rear window. That's how I handle the Texas summer with no AC, so I can assure you that it works.
Any recommendations on 2-door hatches? I generally try 1-2" on the passenger side to swirl the breeze back to the driver's side -- it can also force more draw on the vents without using the fan motor -- but otherwise, the hidden rear vent doesn't move much air, so the A/C crops-in when it gets close to 80F. But, I wont have to worry about that much longer this year
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
