I'm late to the party here...
To fill the pods...
Based on my turbo cars of the past, I had an Oil Temperature Gauge (not sure if there's a sending unit on the Yaris). If you ever affix a grill block or undertray, it might be good info to know the Oil Temp. Oil Pressure is also a good gauge.
Outside Temperature might be a good one...
Otherwise, vacuum, voltmeter, a digital timer, or a custom gauge of sorts could be installed.
I miss the days when the average car came with more than just a tach, speedo, fuel, and temp gauges. I forget the car I drove once, but it had a speedo on one side, and a huge gas gauge on the other. The rest were idiot lights. I like to know what's going on in analog format -- I too crave gauges...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
 _
 _
