Originally Posted by Frank Lee
It was far cheaper for me to just cut 'em! (although I did heat juuuust enough to reshape the cut coil so it would seat nicely) And I'm happy with the ride and handling too.
When you shorten a spring you stiffen the spring rate. Imagine standing in the middle of a 12 foot 2x4 suspended at each end. A 6 foot 2x4 would feel twice as stiff. Cutting may be a better compromise between altered height and minimum cost. Resetting wouldn't be free unless you own a spring shop.
