Old 01-18-2012, 08:16 AM   #5 (permalink)
oil pan 4
Originally Posted by Ladogaboy View Post
What about highway speeds through winding roads or up an incline (i.e., when the velocity is changing)?
You said it your self, you're only changing speed by 5-10mph most of the time. The faster you are going the less that 5-10mph change will matter.
The more the RPMs your wheel or drive train changes the more this mod will be worth. The RPM change in the rotating mass is the only accelerating that matters here.
