Old 02-10-2012, 03:10 PM   #43 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Olympiadis, I like the links you posted. If I understand, not intake restriction but EOC P&G itself might be contributing to a rich AFR in my car because of quick throttle position changes (from off to 9% to 25/26% quite suddenly). Such throttle positions are not nearly close enough to WOT for my 25% smaller diameter intake tube to restrict anything significantly, but the quick rate of change in the throttle position will trigger a brief, small, fuel enrichment. Interestingly, yesterday on the freeway my long term fuel trim returned to 0.00 after engine-on P&G for a while. During the neutral coasting glide phase, short term trim dropped into negatives. Apparently, the MAP sensor is mostly relevant because rapid changes in pressure contribute to the ECU's fuel enrichment response?
Sorry for apparently distracting this thread with the rich AFR issue. Thanks.
