Kach just posted an edit showing the Camaro under the template and it's not too bad. If anything, add some length to the trunklid so it meets the template and call it good. If you are not a bodyman, anything else is a can of worms. KISS (no insult intended)
1969 Barracuda Finished Unpainted Photo 1
You may want to skim over this thread too.
http://ecomodder.com/forum/showthrea...ler-14946.html
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
