Old 03-03-2012, 09:01 PM   #12 (permalink)
briogio
Although you can probably trust your mechanic, I'd still double check the wiring before anything else. I also had this problem with my motor when I originally dropped it in - my 4-wire O2 sensor has 2 identical looking black wires and it'll throw a code if they're reversed.
Ok thanks for that!
If the 5 wire O2 sensor has the same 2 black wires I'll reverse them on Monday and see.
