Old 03-03-2012, 08:38 PM   #11 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Although you can probably trust your mechanic, I'd still double check the wiring before anything else. I also had this problem with my motor when I originally dropped it in - my 4-wire O2 sensor has 2 identical looking black wires and it'll throw a code if they're reversed.
briogio (03-03-2012)
Old 03-03-2012, 09:01 PM   #12 (permalink)
Ok thanks for that!
If the 5 wire O2 sensor has the same 2 black wires I'll reverse them on Monday and see.
Old 03-03-2012, 09:19 PM   #13 (permalink)
what code is it throwing?
Old 03-03-2012, 09:39 PM   #14 (permalink)
Code 48 (LAF sensor)
Old 03-04-2012, 12:19 PM   #15 (permalink)
heated oxygen sensor
is not reading correctly. you have it wired wrong.
Old 03-04-2012, 03:42 PM   #16 (permalink)
Ok we'll check it again, have you heard of the 2 identical black wires?
Old 03-04-2012, 05:25 PM   #17 (permalink)
nope, but i have not played with the honda factory lean burn that much either.
Old 03-05-2012, 07:20 PM   #18 (permalink)
The DX - '91 Honda CRX DX
Last 3: 33.49 mpg (US)
The Race Car - '91 Honda CRX Si
90 day: 28.35 mpg (US)
The DX v2.0 - '91 Honda CRX DX
Last 3: 35.11 mpg (US)
DX v3 - '91 Honda CRX DX
The two black wires are the "heater element" wires for an oxygen sensor. They are both identical and order should not matter.
If your oxygen sensor has a GREEN wire, that is Signal -
-The remaining WHITE wire will be Signal +
If your oxygen sensor has a BLUE wire, that is Signal +
-The remaining WHITE wire will be Signal -
These are usually stated in the instructions that come with the O2 sensor. However, I don't think he oxygen sensor is your problem.
Code 48 is indeed for the Lean Air Flow (LAF) Sensor. This sensor has (7) wires (according to Honda).
I've uploaded this for you: <click here>.
First, see the diagram and table on page 10 and make sure you even have the LAF sensor wired to the ECU correctly.
Once you have verified wiring is correct, go through the trouble-shooting procedure outlined in the rest of the pages. POST BACK WITH YOUR RESULTS.
-A
Old 03-05-2012, 10:29 PM   #19 (permalink)
EF Tunerr, THANK YOU VERY MUCH!!!!!!!!!!!
Old 03-05-2012, 10:41 PM   #20 (permalink)
Bertha - '16 Mercedes Benz Metris
Right on! Let us know what happened.
RETIRED
