Old 05-29-2008, 11:51 AM   #14 (permalink)
SatanicMechanic
The Swift - '00 Suzuki Swift
90 day: 48.92 mpg (US)
The best bang for the buck, is to go with flooded
AC is more moolah. DC components are more common, and if you start scrounging now, you may be able to pick up some used ones before your deadline.
Yes it costs a hell of lot more. When I worked on A.C. Propulsion's 100kw drive system, it cost $25k over ten years ago. Then they came out with the 150kw drive system and that cost $35k. Now they produce a second generation system using IGBT's and the costs are huge.
It is a hell of a lot cheaper to go with a DC setup. The efficencies of the A.C. Propulsion's system is around 95% and I have seen DC setups the vary from 85-89%.
2000 Suzuki Swift
2001 Chevy Metro
1983 Electric Ford Escort
