Old 03-23-2012, 10:14 AM   #33 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Search for "Polyester Taffeta"
At the fiberglass supply shops it is called peel ply. It produces a totally different effect than the mylar I posted, it leaves a flat, textured surface that does not need any sanding to go on with the next layup. The mylar leaves a mirror-like finish, for that last layer before paint. Only need a bit of sanding to provide "tooth" for the paint to stick to.
The only thing to beware of is any kind of coating it may have from a regular fabric store. That coating, if present, would mess with the bond of a successive layer.
Peel ply is useful when you lay up an area, then plan on bonding a wall or bulkhead to that surface later. Leave the peel ply on to keep it clean while you work on other things.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
