Old 03-29-2012, 02:08 PM   #3 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Your Civic will have a "smart alternator" that will boost voltage to 14+ volts or down as low as 12.5 volts or thereabouts, depending on the engine load, speed, and other conditions. I recently dealt with battery failure. Mine was a deep-cycle battery that was not well-adapted to this application, and I had damaged it with too-deep a discharge. Are you using a normal starting battery or a deep cycle one? Starting batteries are not as friendly to P&G, especially in the dark with all the lighting on.
