Old 04-03-2012, 09:43 PM   #4 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I'm game.....
and a none-traditional car
2002 Infiniti Q45 Sport w/258,000 miles.
Can get 30+ on the road with an epa of 22.
MJ Crews
Broker Utility Services
1.Full IMPUL body kit (lower by 2 inches)
2. Grille Block
3. Front underbelly pan & rear under belly pan
4. Increased tire size to 245/50/18 (27.7" diameter) from stock 245/45/18 (26" diameter)
5.Increase PSI to 43psi using Nitrogen.
6.Run Scangauge II instumintation
7.Window tint on all side windows and rear window
8 window visors
9. Custom cold air.
10. rear skirts
11. lowered front end 1.25"
• Did rising gas prices have anything to do with your decision? Where there any other influences?
I have always been interested in getting good mileage. The 02 Infiniti Q45 has a 2.76 rear ratio which helps keep the rpms low when on the freeway. THe car also has a low wieght for its class (3801lbs). And the ecm and tcm adjust to your driving patterns.
It was the perfect 4 door luxury road car to achieve better mpg.
• Have you made any other changes based to increase your fuel efficiency?
Driving smarter is the major change
• Did you get the parts for the modification on eBay Motors? Why?
I have part numerous parts (new & used)for the Q45 on ebay because of the protections provided to the buyer
• Did you enjoy the experience of purchasing on eBay Motors? How long have you been a customer?
sometimes the search process doesnot weed out enough stuff. But all in all it is enjoyable. 6-7 yrs.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
eBayGreenDriving (04-09-2012)
