04-03-2012, 07:06 PM
eBay Motors is looking for participants for a quick survey about why and how you modified your vehicle. To participate, post a reply and we will contact you with more info.
We're looking for testimonials that may be used for a green initiative campaign the eBay team is working on.
Thank you!
–The eBay Motors Team
Please find the survey questions below. This is a brief survey and we appreciate your participation. Please feel free to respond via private message, or simply post a response.
• What’s your name?
• What do you do?
• What modifications did you do to your car?
• Did rising gas prices have anything to do with your decision? Where there any other influences?
• Have you made any other changes based to increase your fuel efficiency? (Driving differently, making fewer trips, etc.)
• Did you get the parts for the modification on eBay Motors? Why?
• Did you enjoy the experience of purchasing on eBay Motors? How long have you been a customer?
We are looking to gather knowledge and testimonials that may be used for marketing or public relations purposes as part of a green initiative the eBay team is working on. Your information will NOT be used unless we obtain consent from you beforehand.
Thank you!
• What’s your name?
• What do you do?
Reason: duplicate posts
The Following User Says Thank You to eBayGreenDriving For This Useful Post:
04-03-2012, 08:59 PM
MPG Militia HMV-25E80+A
Call me suspicious, but why withhold "more info"?
04-03-2012, 09:25 PM
I got my vehicle tinted. I wish i had pictures. It looks real nice. Good for the environment too (less emissions!)
04-03-2012, 09:43 PM
I'm game.....
and a none-traditional car
2002 Infiniti Q45 Sport w/258,000 miles.
Can get 30+ on the road with an epa of 22.
MJ Crews
Broker Utility Services
1.Full IMPUL body kit (lower by 2 inches)
2. Grille Block
3. Front underbelly pan & rear under belly pan
4. Increased tire size to 245/50/18 (27.7" diameter) from stock 245/45/18 (26" diameter)
5.Increase PSI to 43psi using Nitrogen.
6.Run Scangauge II instumintation
7.Window tint on all side windows and rear window
8 window visors
9. Custom cold air.
10. rear skirts
11. lowered front end 1.25"
I have always been interested in getting good mileage. The 02 Infiniti Q45 has a 2.76 rear ratio which helps keep the rpms low when on the freeway. THe car also has a low wieght for its class (3801lbs). And the ecm and tcm adjust to your driving patterns.
It was the perfect 4 door luxury road car to achieve better mpg.
Driving smarter is the major change
I have part numerous parts (new & used)for the Q45 on ebay because of the protections provided to the buyer
sometimes the search process doesnot weed out enough stuff. But all in all it is enjoyable. 6-7 yrs.
The Following User Says Thank You to mcrews For This Useful Post:
04-03-2012, 09:55 PM
I'm interested. You can send me a private message or email darin at ecomodder dottt com.
04-04-2012, 08:32 PM
1. A name is a valuable tool/dangerous weapon to some people on the internet. Perhaps some other time.
2. Freightliner technician, 25 years experience as a mechanic
3. Fixed the previous owners "repairs",
full upper grill block,
partial lower grill block,
PS belt removed,
aluminum belly pan front to back except wheel wells,
engine fan switch,
cool air intake blocked-warm air only,
smooth hubcaps,
MPGuino(no VSS),
rear wheel kilts,
tapered fairings behind rear wheels(in process),
alternator field kill switch,
injector/fuel pump kill switch,
removed AC condenser,
165/65/r14 Potenza RE92(Low Rolling Resistance) tires installed,
boat tail,
5th gear swap from .89 to .75,
removed rear seat and window(weight).
4. I thought my car should get better mileage than it did. I was right.
5. Plan trips ahead, consolidate errands, DWL(Drive With Load),
P&G(Pulse and Glide), predict stop lights, avoid stops, stay alert of other drivers and how they will effect my driving, find the most efficient route for daily commute, keep the car tuned up and the
tires aired up, among others I may have forgotten.
6. I have bought some parts from eBay Motors, mostly for the
convenience and savings.
7. I have enjoyed using eBay since '08.
Good luck with your survey.
The Following User Says Thank You to JethroBodine For This Useful Post:
04-09-2012, 02:54 PM
eBay Motors survey follow up
Originally Posted by mcrews
I'm game.....
JethroBodine & mcrews - Thank you for responding to our survey! I wanted to share with you a bit more of why we want to gather these details.
eBay Motors is looking to for this information to gather testimonials that may be used for marketing or public relations purposes as part of a green initiative the eBay team is working on.
Your information will NOT be used unless we obtain consent from you beforehand. Would it be possible to continue the conversation via phone or regular email? My name is Nancy and I'm part of the team working with eBay Motors in this initiative. Feel free to call me at 650-691-7314 or reply to my email at sanchez <at> airfoilpr <dot> com
Many thanks,
Nancy
