Old 04-12-2012, 06:09 PM   #8 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I have not had much luck with electric coolant pumps.
I think you would be better off with an alt delete.
The electric coolant pump and alt delete don't go together real well.
Could be true, HOWEVER I can tell you from experience that alt delete requires significant $$ for battery if you want to be able to drive any decent distance. That can cost far more than an e-fan.
I've had success with an e-fan conversion. Volvo 240, a 3000 lb. boxy wagon with 115 hp engine so any load removed from the engine was a real help. I had that auto-tranny beast up around 29-30 mpg in summer; the EPA said 19 mpg.
And at a local car show, I saw a guy with Shelby Cobra (I think it was a conversion/kit car... ). He had a couple e-fans switched the same as mine: Temp switch in the lower hose (return). We both agreed that's the only way to go unless your computer has an output to drive the fan.
Coast long and prosper.
