Old 04-10-2012, 08:17 AM   #1 (permalink)
EcoOe812
oe812's Avatar
Mini Titan - '02 Nissan Frontier XE
90 day: 23.14 mpg (US)
Cautiously Optimistic Fuel Mileage (increased tire PSI & adding electric cooling fan)
Ater inflating the tires on my truck to 44psi and installing an electric fan, my fuel mileage has increased from 20.5 mpg to 24 mpg. I will check on my next fill up as my A/C is on full time as temperatures are mid 80's now.
13 Nissan Frontier Crew Cab V6
Sold: 02 Nissan Frontier and 01 Chevy Silverado
Future EcoMods: Build My Tonneau Cover, Grille Damper
Old 04-11-2012, 10:44 AM   #2 (permalink)
In God we trust!
Hip001's Avatar
01 Beetle - '01 VW Beetle TDI
90 day: 42.33 mpg (US)
Black 450h - '14 Lexus 450h
Good job! King cab? I have owned two Nissan trucks, neither one seemed to do well on mileage. I did own a 87 Toyota regular cab with a 4-speed manual shift( not 5speed. Base model truck) that got 30 mpg. & friends that had the Mazda B2000 mid80's truck that claim to get 30's. Have not heard of ANY trucks getting 30's since then.
My 1997 un modded f150 v6 automatic can get lower 20's so I couldn't see a reason to buy a smaller truck.
2014 Lexus RX450h
2008 Toyota Tundra
2007 BMW R1200RT
2006 Jetta TDI DSG
1997 Ford F150
Old 04-11-2012, 11:04 AM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
were you able to remove a fan belt w/ that conversion?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-11-2012, 12:21 PM   #4 (permalink)
In 2006 I picked up about 2mpg on the highway when I switched my suburban to electric fans. Its a good ecomod.
Old 04-11-2012, 02:27 PM   #5 (permalink)
EcoOe812
oe812's Avatar
Originally Posted by Hip001 View Post
...My 1997 un modded f150 v6 automatic can get lower 20's so I couldn't see a reason to buy a smaller truck.
Yes it is a KC. My unmodded 2000 F150 only got 15 mpg on the 5.4 auto.
Old 04-11-2012, 02:30 PM   #6 (permalink)
EcoOe812
oe812's Avatar
I wanted to do the pulley delete but the electric water pump was cost-prohibited.
Old 04-12-2012, 04:08 PM   #7 (permalink)
I have not had much luck with electric coolant pumps.
I think you would be better off with an alt delete.
The electric coolat pump and alt delete don't go together real well.
Old 04-12-2012, 06:09 PM   #8 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
The electric coolant pump and alt delete don't go together real well.
Could be true, HOWEVER I can tell you from experience that alt delete requires significant $$ for battery if you want to be able to drive any decent distance. That can cost far more than an e-fan.
I've had success with an e-fan conversion. Volvo 240, a 3000 lb. boxy wagon with 115 hp engine so any load removed from the engine was a real help. I had that auto-tranny beast up around 29-30 mpg in summer; the EPA said 19 mpg.
And at a local car show, I saw a guy with Shelby Cobra (I think it was a conversion/kit car... ). He had a couple e-fans switched the same as mine: Temp switch in the lower hose (return). We both agreed that's the only way to go unless your computer has an output to drive the fan.
Coast long and prosper.
Old 04-12-2012, 07:59 PM   #9 (permalink)
Same here, the suburban weighed in at about 3 tons with me in it and has 150hp or less. Every little bit helps.
(I have removed some stuff since then, so its a few hundred pounds lighter)
I have another solar panel to add that would make an alt delete good at least for driving to work.
Old 04-15-2012, 04:15 PM   #10 (permalink)
beamer - '91 bmw 318is
90 day: 32 mpg (US)
I made that modification of removing the engine-driven fan and replacing it with an electric fan on my 1988 Ford Thunderbird 5.0 and it made absolutely no noticeable difference.
None.
I had done it mostly to get that slight increase in power but I didn't notice a FE difference either.
