Old 04-20-2012, 01:09 PM   #78 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by mwebb View Post
EGR reduces combustion pressure and
thereby reduces Combustion temperature so warm up time will NOT be reduced if EGR is used when cold.
On the VW TDI is does help warm up times. The Exhaust Gas goes through a stainless steel EGR cooler which is tied into the coolant loop. As the exhaust gas is cooled it heats the coolant flow.
EGR does not get cut off when the system is at normal operating temperature because the primary reason there is EGR
is to reduce NOX emissions
Agreed. Unless it has been modified (tuned).
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
