04-19-2012, 05:19 PM
#71 (permalink)
Aero Wannabe
Originally Posted by Dieselman
Not quite correct. An open EGR valve reduces pumping losses due to the restriction caused by the throttle flap, without allowing any more oxygen into the cylinders.
We are talking about a gas (petrol) engine here right? as the diesel technically does not have a throttle plate because it does not need to operate at a specific air fuel ratio. Therefore both posts may be correct. EGR hurts mileage in some diesels but may help low load mpg in gasoline vehicles due to reduced pumping losses.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
04-19-2012, 06:39 PM
#72 (permalink)
EGR can help diesels get better FE by warming them up faster.
Once up to temperature EGR gets cut off.
04-20-2012, 12:01 AM
#73 (permalink)
maybe maybe not
EGR reduces combustion pressure and
thereby reduces Combustion temperature
so
warm up time will NOT be reduced if EGR is used when cold
EGR could possibly be used to heat the incoming fuel air charge ....
a little bit . possibly to improve fuel atomization a little bit
heating intake air from drawing it across the exhaust manifold would do the same thing , better .
EGR does not get cut off when the system is at normal operating temperature because the primary reason there is EGR
is
to reduce
NOX emissions
04-20-2012, 01:25 AM
#74 (permalink)
aero guerrilla
+1
I'll add that according to my engine's technical manual, EGR is off until the engine reaches a certain temperature. This may be to reduce condensation of exhaust gases on the cold metal elements?
04-20-2012, 01:46 AM
#75 (permalink)
I believe part of the reason for that ^^^ would be to improve startup combustion stability. When the engine is started and cold the ECU retards the spark to increase exhaust gas temperature and warm the catalyst. EGR would cause misfires/torque fluctuation/etc.
As far as the coolant and block temperature goes, dunno.
04-20-2012, 02:09 AM
#76 (permalink)
If I add my own EGR system it will do what ever I make it.
No way I am waisting time/money on a WAI that will reduce FE.
I could care less about NOx reduction.
EGR delete guys all report lower coolant temperatures.
This is for a diesel.
04-20-2012, 03:32 AM
#77 (permalink)
You don't need to make full time WAI, you could make similar flap like old carburettor cars had, exhaust heated air came from pipe and fresh air from another, mechanical temperature sensing element adjusted flap so that there was constantly around +20C air going into intake manifold at cold weather.
One could do that so that he gets full heated air during warmup phase and then flap would change to fresh air?
I remember reading from some study that it was around X% (maybe 4%) increase in fuel consumption because of EGR, but I can't remember if that was diesel or petrol. In that study there were three methods compared, one being EGR, at least one other was injection of something which I can't recall by name, those other methods did not increase fuel consumption and were better at controlling emissions too. However because of my poor memory I can't now locate that document, can't even remember if I linked it here some thread.
It might be saved to my other computer as it can't show PDF documents unless I save them first, if I find it, I post it here, that might provide some interesting points again.
From my experience, when driving longer distances, if I disconnect EGR wires, it improves economy small amount, certainly under 5%, in my mechanical turbo diesel, which has catalyst installed. That I have tested with thousands of kilometers on and off, so I'm sure that it has effect. Another test would be to clean it up as it probably has not been cleaned for 300 000km, that might change things a bit, I guess.
04-20-2012, 01:09 PM
#78 (permalink)
Aero Wannabe
thereby reduces Combustion temperature so warm up time will NOT be reduced if EGR is used when cold.
On the VW TDI is does help warm up times. The Exhaust Gas goes through a stainless steel EGR cooler which is tied into the coolant loop. As the exhaust gas is cooled it heats the coolant flow.
is to reduce NOX emissions
Agreed. Unless it has been modified (tuned).
TDi=fast frugal fun
01-03-2015, 10:14 AM
#79 (permalink)
1993 Mercedes 300D TD EGR inhibition: fiasco
Yes, I inhibited the EGR working by simply disconnect the vacuum pipe that makes it work. Last tank complete was without it and fuel yield was significantley lower.
You can see it in my fuel log.
Oldbeaver
Mercedes 300 D turbo 1993
01-03-2015, 02:56 PM
#80 (permalink)
Was your coolant temperature lower on your diesel with no EGR?
