Old 05-03-2012, 09:57 PM   #4 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I've seen a couple Civics (both gen 6, 1996-2000) with tempermental ignition switches. The electrical part is/was fine, but mine is sometimes difficult to turn. You have to angle the key just right. I test drove another Civic, same problem except that one was worse.
So I'd recommend a cutoff switch if you can figure out where and how to wire it up. Save the wear and tear on the ignition lock mechanism. My cutoff switch is a toggle type, a quick swipe of a finger is all it needs. Easier than turning the key, and will never lock the steering wheel if you mess up.
Coast long and prosper.
