Old 05-03-2012, 11:36 PM   #171 (permalink)
mjspiess
The Blue Bomber - '95 Geo Metro
90 day: 52.09 mpg (US)
Theoretically this Ford MAP sesnor mod could be done on ANY vehicle with an aftermarket cruise control and ANY vehicle with a VSS PPM of 8000 with an OEM cruise control. You can check your vehicle's PPM here where is says VSS search on the right: Rostra Precision Controls | Technical Support
With this particular mod, you're not using your OEM MAP or MAF sensor to trick the cruise (not to say that can't be done), but you're using the Ford MAP sensor which can be "plugged" into ANY vehicle. All you're doing is running a vacuum line from the Ford MAP sensor to the intake manifold and the sensor does the rest. It monitors intake manifold pressure and sends that data to the cruise control and the cruise adjusts accordingly.
