05-17-2012, 08:05 AM
#11 (permalink)
How do you know an injector kill switch wouldn't allow it to work?
One way to find out is to intentionally stall the truck with the gears/clutch while leaving the key alone, then try roll starting it.
Find a hill, and intentionally stall it at the top by popping the clutch in a high gear from a stop. Then roll down the hill and try clutch/bump starting.
