Old 05-24-2012, 01:10 AM   #46 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by OneOfFew View Post
I'm going to try some different stuff tomorrow and report back. I think I'm going to put a scope on the wire to see if it is holding voltage after the switch. If so I may be able to pull it down. If all else fails I'll get 2 dpdt relays to disconnect EVERY control wire on the alternator.
Here is the wiring diagram for the charging system, taken from the Honda Service Manual for the 1996-1998 Civics. You'll see that the large gauge white wire running from the alt to the battery also has a connection back to the regulator, seemingly still inside the alternator. I think that's the culprit, here. What do you think?
OneOfFew (05-24-2012)
