Old 05-27-2012, 12:53 PM   #4 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Thanks guys.
Originally Posted by nemo View Post
Congratulations on the best tank. Doing anything different?
All the various mods over 3.5 years plus finally got lean burn working below 61 mph (not really a "mod" but it sure helps).
I probably have to credit any recent improvement to the weather and "summer" fuel mix.
I did note engine running kinda warm one day, not centered at its usual 182ºF. due to a bit too much grill block. Considering running more grill block regularly, and keep an eye on the temp via ScanGauge. Also considering a hotter thermostat, but Civics have the t'stat low down at the lower rad hose return, and with the belly pan, changing it could be a sloppy mess. So I'm tempted to do either but also a bit reluctant. Looking for any pointers you guys may have on that.
Coast long and prosper.
