Old 07-02-2012, 03:21 PM   #54 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by jamesqf View Post
That's wrong, because torque is an angular quantity. It's the product of a force applied times the distance from the axis at which it's applied. (Think of a torque wrench.) And of course pounds and feet are just English units: in metric it'd be measured in newton-meters.
Exactly right. If I hung my 185lb body from a lever that is attached parallel to the ground at a distance of 1ft from the fulcrum, I impart 185ft/lbs of force. Whether anything moves is irrelevant.
Automotive texts refer to torque when tightening various bolts. Tightening a lug nut to 75ft/lbs means to turn until that much resistive force is encountered. It says nothing of what distance to turn.
