Old 07-10-2012, 07:47 AM   #28 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
My current tank is at 75.4 mpg. My route has gotten very friendly (no classes means I go to the office less) and I am back to using my alt delete in the challenging 50 mph steep hill environments.
Originally Posted by pletby View Post
Learning Pulse and glide and EOC. I've got a loose grasp of driving with load, but have no topography to speak of here on the prairies, so I only really get to use it on bridges and over/underpasses. I have no instrumentation yet that works with this car.
Petby, do I understand you correctly? DWL is not about topography. I thought that too. Then I learned it is about the load on the engine from operating the car, independent of topography (though effected by it). If you get a vacuum gauge installed, people here can help you learn the technique, which involves brisk acceleration at a specific vacuum range, followed by cutting the engine, gliding, and bump starting to repeat the process. You would see a major jump in FE from such a practice.
On a good morning I can get through 20 km of city driving with only stopping twice. We don't have freeways. Afternoon is stupid with traffic. Much stopping.
This stop-go traffic is little or no problem for me on the LA freeways because I cut the engine, bump start, close gaps DWL... sometimes traffic improves my mileage, depending on topography. You have got to learn this. It will change how you experience the road. I would put the vacuum gauge at the top of your mods list, and you can get them from the ricers cheap and to mount in the moldings of the A-Pillar beside your instrument cluster.
Originally Posted by Gasoline Fumes View Post
I need to do more aero stuff and install my CRX HF trans for a 1000 RPM drop in cruising RPM.
This transformation would be fun to watch. Please do this. If you were close to me, I'd come help for the experience.
Originally Posted by basjoos View Post
Most trips get about 70 to 80 mpg.
... in a twenty year old car, driving normally on the freeway. Still one of the absolutely coolest cars here. Though 3-wheeler's Insight is amazing.
Originally Posted by PaleMelanesian View Post
I just replaced my CV axles so I'm no longer pop-pop'ing around corners.
The good news for Team Honda though is I'm driving the Insight during the warm months, when it can get spectacular MPG, and the Firefly (Metro ) in the cold ones, when it doesn't.
I don't fill up the Insight a whole lot (I don't commute). My next fill will probably be later this month or very early August. The good news is I think it's going to be my best tank so far: 93.5 mpg showing on the OEM computer @ 700 miles (no promises). ~1/3 tank remaining.
That will be a great addition. We have 27 cars on Team Honda, currently. More than most of the other top ten teams combined. You'd really bring up the average with a 93 mpg log entry!
