Old 07-10-2012, 12:07 PM   #13 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by TXwaterdog View Post
Those rims look very functional. It appears to suck air out from under the car. I bet it cools the brakes quite well. And they probably help keep the car glued to the ground. Now if they used them well enough to route air through them and help cool the engine/ driveline then that's even better. If they channel forward then it might even propel the car forward a bit. Overall looks like a design I've had in my head for a while.
You are kidding right?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
