Old 08-17-2012, 03:45 PM   #7 (permalink)
oil pan 4
I would like to make a hybrid pressure washer.
My pressure washer pump froze last winter (pressure washer was in side the house), found a new pump and put it on there and later on I was able to repair the old pump so all I need to do is find a 220v motor that is at least 5hp, I have 70 feet of 220 volt extention cord witch would be use full.
I have the same problem, 3/4'' keyed shaft hole on the pump and all the motors are 1/2'' or 5/8'' shaft. I don't mind buying the motor if they had a 3/4 shaft or an adaptor.
Would like to set it up so I could run gas or electric and change out the nozzle then run both if I really needed some cleaning power.
