Old 08-28-2012, 05:47 AM   #29 (permalink)
oil pan 4
Gas turbines have a very narrow high effeciency margin.
Usually you want the piston engine at its most efficient speed and load while the turbo is usually running at 10% or 20% efficiency.
You could size both the pistion and turbine engine to be most efficient at cruising speed but that would be all the vehicle would be good for. Every other driving condition would be less drivable. You would have to have a tiny engine turning about 2500rpms with a properly sized turbo boosting it to between 10 and 30 psi.
