Originally Posted by JethroBodine
After a bit of investigation, found one of my newly rebuilt injectors leaking around the body. Tried resealing the body of the injector, but no such luck. I happened to bring one of my old injectors, installed it, and no more leak...on that injector, anyway. #3 is leaking a bit also. Not as much as #1 was, but I still need another one.
Is it possible the leak is coming from somewhere along the fuel line and only showing at the injector?
