Originally Posted by jalmir
and looks like Honda's schematics don't agree with you!
Eh?
Did you look at the schematic? Yel/Blk positive to each injector from PGM-FI Main Relay 1, negative color varies by injector and goes directly to ECM/PCM. How does it not agree?
Mine is an '01, here is a more detailed
Wiring Diagram. It's drawn differently, but has the same grounds going to the ECM/PCM and yel/blk positive feeding the injectors.
