Old 07-17-2012, 02:05 PM   #11 (permalink)
Then you'll have a cel
Old 07-17-2012, 06:04 PM   #12 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
Originally Posted by greasemonkee View Post
Based on the above diagram with what is visible, I would cut the ecm wire or red/yel wire, this will have the least amount of current of any of the lines and will cut off the ecu along with the fuel pump/injectors/ign, ect. If I could see the rest of the wiring, that may change but I doubt it.
Cutting the FP only will allow fuel to trickle through the injectors under low manifold pressure. Some cars will even run without the FP being on if they are of the centrifugal type.
the only red/yellow wires i see are the relay 1 control, and the purge valve control
Originally Posted by bandit86 View Post
Just look for the injector ground and cut that
each injector is individually grounded by the ecm
Old 07-17-2012, 10:14 PM   #13 (permalink)
Relay 2 is operated by Relay 1, interrupt signal to relay 1 and you cut everything. You'll probably get a CEL when you interrupt the circuit which will kill ecu and FP, but when the circuit is closed it should reactivate with no CEL and nothing stored in the memory. Unless your generation has some queer test routine in the ecu it should work. I do all of my cars this way, even use it for an anti theft.
Old 07-20-2012, 02:56 PM   #14 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
It works! I cut the red/yellow wire between the ECM and first relay, and (at least sitting in the driveway) it works perfectly. Engine shuts down, MIL comes on, battery and oil lights don't, everything else stays functioning.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Fat Charlie (06-03-2013)
Old 07-20-2012, 09:31 PM   #15 (permalink)
Moderator
Vman455's Avatar
Oops--seems I spoke too soon. The kill switch is tripping the immobilizer system, so I have to key off anyway to reset it. Looks like I'll have to hunt down the injector power wire under the hood after all.
Old 07-20-2012, 10:02 PM   #16 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Well you'll figure it out... until then, at least you have a nice looking switch.
Old 07-20-2012, 11:03 PM   #17 (permalink)
Sorry that didn't work out, but thanks for reminding me to never buy a post 2000 car.
Old 09-06-2012, 06:50 PM   #18 (permalink)
darcane's Avatar
Trying to figure this out for my '01 HX.
Did you ever figure out a good solution? Did you interupt the Yellow/Black wire to the injectors similar to SentraSE-R?
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 09-06-2012, 08:03 PM   #19 (permalink)
jalmir's Avatar
Avante - '02 Hyundai Elantra GT
90 day: 32.07 mpg (US)
and looks like Honda's schematics don't agree with you!
Old 09-06-2012, 08:29 PM   #20 (permalink)
darcane's Avatar
Eh?
Did you look at the schematic? Yel/Blk positive to each injector from PGM-FI Main Relay 1, negative color varies by injector and goes directly to ECM/PCM. How does it not agree?
Mine is an '01, here is a more detailed Wiring Diagram. It's drawn differently, but has the same grounds going to the ECM/PCM and yel/blk positive feeding the injectors.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
