Old 09-09-2012, 04:03 AM   #2 (permalink)
oil pan 4
Do both.
That is what I am likely going to end up doing.
I went with 2-3 inch taller tires back in 2008 and at some point I would like to go from a 3.08 rear to 2.73 rear gear also.
If you had 225/70/14 that is a 26.5 inch tire, 3.73 rear end, drove 65mph and had an over drive of 0.7 you would be turning 2152rpm.
If you only changed your rear end to 3.45 gears you would drop your 65mph engine speed to 1990rpm
Keeping the 3.73 and only switching tire size to 29 inch tires would drop engine speed at 65mph down to about rpm 1966rpm.
Going to 3.45 gears and 29 inch tires will drop engine speed at 65mph down to 1819rpm.
Keeping 3.73s and going to 30 inch tires will drop engine speed at 65mph down to 1901.
hat_man (09-13-2012)
