Old 09-10-2012, 04:36 PM   #19 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 51.04 mpg (US)
Originally Posted by a8ksh4 View Post
For the lift - just grabbing it and lifting it up might be an option. I'll have to think about how it'll latch in the up position if I do this. It really needs to be on sliders/rails of some kind so that it doesn't jerk around and break if it's windy out. The center pull slides didn't excite me too much, but ball bearing drawer slides look perfect. They seem sturdy enough and are way cheaper than the strut-channel & trolleys that I was planning on using before.
Great project! A very low tech solution may be to lift it manually (I think it will be very light) and prop it up with a couple of rods or poles. As long as they are wider at the bottom by the tailgate hinge, the trapezoid shape should stop it from shifting in the wind. However, you may want to add some straps to tether it down so the wind cannot lift the whole thing while it is set up. It is amazing how quickly the wind can come up when you are camping.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
