Old 09-12-2012, 10:25 AM   #22 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Originally Posted by Quezacotl View Post
By the way, NoD~, what's ASD relay?
ASD = Automatic Shutdown Relay (It's a Dodge thing); it's the relay that the ECU uses to "turn on" both fuel injectors and ignition system. W/o this relay, the car cranks over, but never starts (no fuel, no spark). When you turn the key back to kill the engine, like I did before the button, it ECU turned off this relay to kill the engine. So, the button basically mimics what the ECU does anyways by removing ground from the relay.
Please clarify how these kill switches work? Do you hold the button down for the duration of the coast?
Just like you would with pulling the key back for a few seconds, then putting it back on (but not to the START, where the starter kicks in to get your engine going again), you hold the button for a few seconds. If I throw it in neutral and and it's idling at ~1K RPM, it only takes about 1-2 seconds until the engine reaches 0RPM. If I'm higher, like 3K RPM, it may take a bit longer, 2-3 seconds, because it has to drop quite a bit higher. Worse case scenario, you don't hold it long enough and the engine re-engages and will kick back up like you just started it. This happened a lot with the key, but has not happened once since I put the killswitch in.
Also, you have a bit of an "indicator" with the killswitch you wouldn't have had with the key. The key disables the cluster, which means you don't see the oil light kick on or check engine light turn off when the engine stops running (lol, not everybody will have the CEL though). With the kill switch, I just press and hold until the CEL turns off and the oil light kicks on. At that point, I know the engine is definitely off.
The Following User Says Thank You to NoD~ For This Useful Post:
NeilBlanchard (09-15-2012)
