Old 09-05-2012, 05:21 PM   #11 (permalink)
Synchronicity's Avatar
TGV - '11 Renault Traffic L2H1 2900 long wheelbase cargo van
So the rest of the electrics work. That's good.
But does the brake booster still work?
What about power steering?
http://www.Tenerife-Training.net Pro Bike Hire in Tenerife
Old 09-05-2012, 05:33 PM   #12 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Sort-of and No. The break booster retains vacuum for quite a long period of time. Then again, I rarely need to REALLY use the brakes... so for all I know, It's not working very well... I usually bump-start my engine before a stop and glide until then, so I guess I'll need to do some tests on that!
As for Power Steering, without an engine turning the pump, it simply will require some good muscle... unless you are electric power steering (seems most newer cars are heading that way). For my car specifically, I converted my rack to a manual rack anyways, which is noticeably better than the lines looped.
Old 09-05-2012, 05:47 PM   #13 (permalink)
jalmir's Avatar
Avante - '02 Hyundai Elantra GT
90 day: 32.07 mpg (US)
gotta take the time to install that switch ... my elantra isn't as simple as hacking the key switch since my OEM mpg meter will be turned off if I do so.
So I did a little digging and found out there is a injector fuse in the engine compartment, so it should be quite easy to install some wires with a switch and an inline fuse in place of that regular "car fuse". Easily reversible and no wire cutting and such!!!
Old 09-05-2012, 08:16 PM   #14 (permalink)
Red Light Avoider
pletby's Avatar
My Civic - '00 Honda Civic DX
90 day: 46 mpg (US)
I totally agree with you in that I had the feeling of 'I should have done this a long time ago'. I just happened to replace my car last month and this was the first thing I did. What a difference!
Old 09-05-2012, 08:38 PM   #15 (permalink)
looking to get 100mpg
lsemple's Avatar
Si Civic - '93 Honda Civic Si
90 day: 41.16 mpg (US)
I've had the kill switch in my civic for about 2 months now. Works nicely,
I converted it now so that you have to push the button to kill the engine, which it does via cutting power to the main Fuse for the main relay under the dash.
I used a relay switch to do this.
Old 09-06-2012, 08:16 AM   #16 (permalink)
Prophecy99's Avatar
Maxima - '02 Nissan Maxima GLE
noob question whats EOC
Old 09-06-2012, 08:38 AM   #17 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Engine Off Coasting.
Coasting with engine off
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 09-11-2012, 10:30 PM   #18 (permalink)
Asphault Camo - retired - '05 Honda Civic SE
90 day: 35.81 mpg (US)
Asphault Camo Kid hauler - '98 Honda Odyssey LX
90 day: 24.33 mpg (US)
welcome
Welcome to the forum. No apologies necessary for being new, just a big welcome and all the help you can get.
Here's a couple resources to get you started:
Glossary: SVOBoy has prepared a thread that tries to capture most of the acronyms like EOC that you already ran into. There are so many that I sometimes forget what ones mean that I already looked up before. Anyway, go to the top of this page, and under the header that says ecomodder in the funky font you will see a row of links for different parts of the website (Home, Forum, Blog, ...). The furthest to the right is Glossary and it will take you to SVOBoy's thread which identifies most of them or at least the long form of the words.
Then if you go to the 100+ Hypermiling Tips and/or 65 Efficiency Mods you will also find many of them explained relatively simply.
Then if you still hunger for more information another good tool is the search which can be found below "Home" (below the row of links mentioned) on the far left near but not at the top.
Cheers.
Old 09-12-2012, 02:04 AM   #19 (permalink)
Originally Posted by Weather Spotter View Post
If you make a wright up I will add it to our wiki might help others do the same!
I added it to wiki in existing page
Engine kill switch - EcoModder
EDIT: I'm stupid, you meant a post before my instruction
By the way, NoD~, what's ASD relay?
Brrrmm
Old 09-12-2012, 07:05 AM   #20 (permalink)
Please clarify how these kill switches work? Do you hold the button down for the duration of the coast?
