Old 09-12-2012, 02:49 PM   #263 (permalink)
Domman56
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Originally Posted by hondo434 View Post
Domman56, This thread is here because I tried a set of magnets on my car and they increased my milage as described earlier. To check results I tried them on my other car and similar results occurred and still have increasde milage for the past few years. I don't know why this happened. That is why I asked for help in duplicating the experiment.
I think the fuel is affected to some extent and caused the ECU to go to an economy mode. That's my theory. An engine analyser would need to be hooked up to monitor changes to ECU settings to verify if that is the case.
Other than that I am unable to give any other opinion.
SOOO assuming this did work and you think it caused the ECU to go into an eco mode, Are you saying this could not be duplicated with a car without an ECU and instead it would cause the car to run Lean or Rich?
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
