09-11-2012, 08:33 PM
#261 (permalink)
Study this thread: http://ecomodder.com/forum/showthrea...ery-11445.html
Then document the results and test conditions, doing everything in accordance with that thread. Then we will believe that you have accomplished something.
09-11-2012, 09:49 PM
#262 (permalink)
home of the odd vehicles
Originally Posted by Domman56
OK i haven't been on here in forever but WHAT is he freaking talking about? How would magnets even work? i don't understand the concept
Don't bother, its new age science like teleapthy
09-12-2012, 01:49 PM
#263 (permalink)
Tank - '76 Chevy El Camino Classic 90 day: 25.89 mpg (US) Sabrina - '91 Mercedes Benz 190 E 90 day: 37.07 mpg (US) Angel - '88 Mercedes-Benz 420SEL Last 3: 23.01 mpg (US) Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Originally Posted by hondo434
Domman56, This thread is here because I tried a set of magnets on my car and they increased my milage as described earlier. To check results I tried them on my other car and similar results occurred and still have increasde milage for the past few years. I don't know why this happened. That is why I asked for help in duplicating the experiment.
I think the fuel is affected to some extent and caused the ECU to go to an economy mode. That's my theory. An engine analyser would need to be hooked up to monitor changes to ECU settings to verify if that is the case.
Other than that I am unable to give any other opinion.
SOOO assuming this did work and you think it caused the ECU to go into an eco mode, Are you saying this could not be duplicated with a car without an ECU and instead it would cause the car to run Lean or Rich?
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
09-12-2012, 01:57 PM
#264 (permalink)
Always Too Busy
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
The Following User Says Thank You to Flakbadger For This Useful Post:
09-12-2012, 02:23 PM
#265 (permalink)
Alexa - '07 Honda Civic LX 90 day: 38.32 mpg (US) FX - '06 Infiniti FX35 90 day: 17.98 mpg (US) Priya - '03 Saturn Ion 3 90 day: 27.81 mpg (US)
send mea few of those tabs and i will run them through some "scientific" tests
09-12-2012, 02:24 PM
#266 (permalink)
Domman56, I have not done any experiments with older cars. therefore I cannot assume any benefits. But by the use of deduction, If there is a benefit( which I am assuming) with ECU vehicles than there could be some benefits may not better milage, but possibly with more efficient burning of fuel. If the fuel IS improved and the fuel burns hotter or cleaner, these benifts could add life to engine by less blowby and cantaminents entering the oil.
11-09-2012, 06:53 PM
#267 (permalink)
Just purchased a new Nissan Maxima. I will attempt to do a fuel test.
I will do a full tank test for a few tankfuls and get a base reading, without any magnets then I will install fuel magnets and take reading, then will add magnets on air tube and take readings.
Shortly, we will be going to Florida, so will get a lot of highway miles to test.
11-09-2012, 06:56 PM
#268 (permalink)
11-09-2012, 09:44 PM
#269 (permalink)
Originally Posted by MetroMPG
ditto.
or don't bother.......
11-10-2012, 10:31 AM
#270 (permalink)
MetroMPG, considering my situation, brand new car, taking a trip of 3-4000 miles (with my wife),Going over mountains with first and last tankful, temperature much colder on last tank,using cruise control,mostly flat highway.I will check tire pressure, note any weather changes etc. I will probably be filling tank at each distination point. How would you set this up?
